#1 2012-09-25 20:45:16
- renlev
Re : Cherche 4 moulures de lèche-vitres(weather strips)Renault Alliance1985
J'ai un Renault Alliance convertible 1985 avec 1.7L et je recherche un endroit ou quelqu'un qui aurait à vendre les 4 moulures lèche vitres (weather strip).
Merci de m'aider, je viens du Québec.
#2 2012-09-25 22:43:54
C'est malheureusement juste introuvable.....
#3 2012-09-25 22:57:20
- renlev
Merci, j'apprécie de savoir. Il me reste si quelqu'un a une voiture en pièces détachées.
#4 2012-09-26 08:35:35
Salut.
Pourrais tu nous en dire un peu plus sur ton alliance ? Et mettre des photos
Depuis quand l'as-tu ?
Nous aimons bien lire les histoires d'alliance
Merci.
Cédric.
#5 2012-09-26 16:04:18
renlev, those pieces are very rare, i have searched with no luck.
I am currently rebuilding a set for one of my restorations, i will put together some photos and text on how to restore them.
It will take me a few days to get that done, be patient!
Geoffrey
#6 2012-09-27 13:07:46
- FERRAZZI GAËL
HI Geoffrey!
We are very interresting in your weather strip restoration, so we are waitting for you about your pictures and text! Thanks a lot!
#7 2012-09-27 19:57:21
OK, i will try to get this to work!
First, remove the old felt and wiper lip with the belt sander.
Next, fill all cracks with 'super glue'. Sand off any extra glue.
Clean with soapy water, thoroughly dry, then coat with Plasti-dip.
This is new belt weatherstrip from Fairchild industries, #1181 mr172x.
I ordered it through Rock Auto .com.
Cut to proper length
Test fit
Use this adhesive to bond to the outer piece, then when you install on the car, you will drill holes for screws, or use self tapping screws
Dernière modification par cvslawrence (2012-09-28 17:09:32)
#8 2012-09-28 10:27:17
intéressant ! thanks Geoffrey !
#9 2012-09-28 12:55:52
- FERRAZZI GAËL
Very good do it yourself Geoffrey, I'm going to try this on my Alliance....
Thanks
#10 2012-09-28 17:11:57
Thanks for the edit Cyrille, i added a few more pics.
I managed to do it right this time!
#11 2012-09-28 19:49:00
I will send my items
Great job
#12 2014-02-15 08:02:08
Bonjour a tous , sujet tres interessant ..... ce serait pas mal de penser a ceux qui ne maitrisent pas ou mal l'anglais comme moi , de maniere a bien comprendre ce qui est dit dans le sujet
#13 2021-03-04 21:32:20
- Hervé D
Bonjour , je suis également intérèssé car Miss Blue en à besoin ? Je ne maitrise pas non plus l'anglais Herve D
